Re: Farmall H ---- hard to start
Posted by Michael Soldan on October 10, 2002 at 17:30:36 from (216.46.130.116):
In Reply to: Farmall H ---- hard to start posted by Don LC on October 10, 2002 at 16:38:33:
Don , it sounds like your H almost starts then is flooded when you choke it for the 5 or 6 lifts. I would give it about half throttle and pull the choke about half and hit the starter. Both my H's start this way, then I play the choke till they smooth out. My one H will flood if I give it full choke for 5 or 6 lifts(RPMs)with the starter engaged.In the warm weather I just hit the starter button. As for the plugs I have Champions in all my Farmalls but I really believe there are better plugs and one H that is restored should run perfectly and every once in a while I get a high rpm miss then it will disappear..I am going to try Autolite 3116 plugs. Good luck with your H.......Mike in Exeter Ontario
Post A Followup
: Re: Re: Farmall H ---- hard to start
