Re: Farmall H cooling problem
Posted by lowercase dick on October 11, 2002 at 20:21:32 from (209.244.79.181):
In Reply to: Farmall H cooling problem posted by Rod on October 11, 2002 at 05:09:02:
I don't have an H, but I do have a 300U, and I learned a bit more about the way its thermostat is set up than I really wanted to know a while back. I'm going to assume the H is similar, and let someone who knows different shoot me down if I'm wrong. Sorry for the long post which follows. The original (and CaseIH replacement) thermostat for the 300U is a more complicated (and expensive) item than the automotive one you're trying to use. In typical automotive system the recycle loop through the engine is always open, and the thermostat only controls flow to the radiator. The 300U (and I expect the H) was originally set up so that the thermostat could completely shut off the recycle loop when the engine was hot enough to require cooling by the radiator, and conversely, so that flow to the radiator was shut off completely when the engine was stone cold. If I put a typical automotive thermostat in my 300U, I end up with the water pump deadheaded until enough heat reaches the thermostat (mainly by conduction through the block since no water is circulating) to open crack it open. At that point, I start to get flow through the recycle loop and then to the radiator as the thermostat opens up further. I expect the H is the same. It sounds to me as though your system is so clean and efficient at cooling that you aren't able to get away with using the cheap thermostat. First thing I'd try is running once with no thermostat at all and see if the temperature cycling stops. If it doesn't, you've really got a gremlin loose in there somewhere. If it does stop cycling, and you want the engine to work properly, I'd suggest either spending the $20 for the CaseIH thermostat, or try drilling a "small" hole (3/16" maybe??) in the valve of your automotive thermostat so that it doesn't shut off the recycle flow through the engine completely. This should then allow the thermostat to monitor the engine temperature accurately, and work much better (assuming you get the hole size correct). Hope this helps rather than confuses. Good luck.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
