Re: Re: Farmall H cooling problem
Posted by Leroy on October 13, 2002 at 19:20:50 from (204.31.32.124):
In Reply to: Re: Farmall H cooling problem posted by lowercase dick on October 11, 2002 at 20:21:32:
I think this guy has a solution to your problem if it's caused by the thermostat closing it too tightly and then opening when it finally gets hot enough. I'm assuming that the thermostat you're trying to use has a hole of about 1/16 inch diameter. Enlarging it slightly should allow enough coolant through so that the thermostat should follow the temperature of the head.
Good luck.
Post A Followup
: Re: Re: Re: Farmall H cooling problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
