Farmall Tractors Discussion Board
Re: H is pumping oil out around a spark plug. (?)
Posted by ltf in nc on August 23, 1999 at 18:37:26 from (206.228.213.17):
In Reply to: H is pumping oil out around a spark plug. (?) posted by Johnny Angel on August 23, 1999 at 15:48:22:
What you are seeing looks like oil but it is probably unburned gas and carbon. This raw gas has a tendency to leak by the plug gasket. It is present because that cylinder is not firing. Verify that you have spark on that cylinder and if so install a different plug. If you do not have spark replace the plug wire and maybe the distributor cap. Once the cylinder is firing your "problem" will disappear.
Post a Followup
: Re: Re: H is pumping oil out around a spark plug. (?)
