Re: farmall 460 rear axles
Posted by Hugh MacKay on October 13, 2002 at 15:16:47 from (209.226.247.127):
In Reply to: farmall 460 rear axles posted by farmall650 on October 13, 2002 at 13:45:27:
I would check this a bit further. There was a discussion on here some time ago re: problems breaking axles on 460s using mounted corn pickers. They were replaced with the heavier 560 axles, since the 560 axle is larger diameter 560 axle cariers would also have to be used. I remember this as I was left a bit red faced on issue. You put a call out to RPM he has the parts number for interchange. 400 axles and cariers would be same as 560, it should work, just may as well know ahead of time what needs to be changed. I am thinking bull gears and pinions??????
Post A Followup
: Re: Re: farmall 460 rear axles
