Wearing out the ring gear
Posted by williamf on October 19, 2002 at 04:31:24 from (66.82.9.15):
The starter on my H is more and more often failing to engage. Makes a terrible grind. The teeth on the bendix look good, but the ring gear doesn't. It's only bad in the one spot (I've never understood why the engine always stops in the same place.) and short term I'm turning the engine ninety degrees when I park it to keep from finishing it off.
I know you can pull the clutch without splitting the tractor, but I don't know that the flywheel will come out that way. What are the chances I could pull the clutch, unbolt the flywheel, turn it ninety degrees, and bolt it back up. I'm willing to try a lot to avoid splitting the old boy.
Thanks, Wm
Post A Followup
: Re: Wearing out the ring gear
