Re: Re: Re: 560 Farmall - hydraulics
Posted by Wheels on October 19, 2002 at 19:56:13 from (205.243.25.196):
In Reply to: Re: Re: 560 Farmall - hydraulics posted by Hugh MacKay on October 19, 2002 at 03:31:11:
Hugh, I don't know if you could kick them, I know they would wiggle from one double to single with out a roll pin by just using the hydralic levers. I had this problem this fall with my 560 on a TMR mixer running the discharge augers. We could reach down and turn them back into place with our fingers. With the roll pins you need a pliers or wrench to turn it.
Have a good day
Wheels
Post A Followup
: Re: Re: Re: Re: 560 Farmall - hydraulics
