Re: regulator smoking
Posted by garytomaszewski on March 28, 2009 at 08:54:18 from (4.131.20.139):
In Reply to: regulator smoking posted by Michigan A on March 28, 2009 at 08:26:36:
If I read your post correctly you have fried the regulator (polarized the field to pos ground ??? WTF). You polarize by touching the regulator armature terminal to the regulator battery terminal (REGARDLESS of system ground). You do this before you start the tractor.
