Posted by Michigan A on March 28, 2009 at 08:26:36 from (66.19.17.59):
I have owned this 640 with 6 volt, positive ground for over 2 years and it has always charged fine. Over the winter I had it in the pole barn with the sheet metal off and noticed the old wiring was cracked and bare in several places. I replaced the wires one by one using the wiring diagram. Wiring to the regulator was fairly easy with the hood off. The old battery was weak so I got a new 6 volt. I don't have any lights or light switch. The old ignition switch had to be replaced, so I got a new one from TSC. With new battery in, new switch, and wiring in I polarized the field to pos ground. Now when I start it up it charges about +8 and runs fine but after about 1 minute I see a small amount of smoke out of the regulator. Any ideas about most likely cause? I think the wiring is correct as I double checked each connection carefully. Thanks in advance for any ideas or suggestions!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
