Re: Farmall Super A Tranny and rear end??
Posted by ScottyNY on October 22, 2002 at 17:34:38 from (151.202.83.110):
In Reply to: Farmall Super A Tranny and rear end?? posted by Bob on October 22, 2002 at 16:39:02:
It's not that bad a job, Bob, if you're set up to split the tractor. You might be able to get the bolts off that joint to split between the torque tube and the tranny so that you can roll the rear end back, but it's doubtful. The space to turn a wrench through there is more than tight and the bolts are even tighter. In the long run it will probably be easier to split behind the engine and then take the torque tube off. Sounds worse than it is. There are four bolts, two facing forward, two aft, on the joint between the shaft and tranny. Once that joint's open, there's a bolt through the tranny side of the joint with a washer beneath. After that a two-point puller will pull it in good order. Then it's just a matter of taking off the collar and replacing the seal. If the gasket on the lower cover is seeping, well, no time like the present. The seal and the gaskets (one behind the collar around the shaft, the other around the lower cover)are still CaseIH parts. If your local dealer can't get them, Carter and Gruenwald has them. Most important part in splitting is the safety, supporting things so they don't fall on you. The A is not too bad, better than a B, anyway, for balance. I've read threads about running a stout bar through the cultivator mounts and supporting each end of the bar on a jack stand. Hope this is not too much detail, but still enough. Email is above if I can help more. Good luck! ScottyNY
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
