Re: Stuck engine on an M
Posted by Bob in SE Nebraska on October 22, 2002 at 17:39:04 from (162.40.71.24):
In Reply to: Stuck engine on an M posted by Larry on October 22, 2002 at 17:26:57:
Larry, I have had three tractors with stuck pistons and was able to remove the pistons and re-use the sleeves. This took much time and work so when I got an H with the same problems, I removed the engine. With the engine upside down on blocks over a concrete floor, I bashed the piston and sleeve out with a pipe and a very large hammer. I had to replace the pistons and sleeves but it sure did save time and work.
Good luck with your M.
Bob
Post A Followup
: Re: Re: Stuck engine on an M
