Stuck engine on an M
Posted by Larry on October 22, 2002 at 17:26:57 from (216.212.40.186):
I'm looking for advice. I"ve got an M that I'm about to overhaul. Its got two stuck pistons, and I'm planning to either hone the liners, or replace them and do whatever else it needs to bring it back to useable condition. I've got the head off and the pan off (they have been off for a year, soaking in brake fluid---PB blaster---diesel fuel....you name it, I've tried it... Any way its time to finish it. My questions are...Is it better to pull the engine and the crank and then remove the pistons and liners, or to do it while the tracor is still all together?? I'm gonna pull the engine anyway, to replace the seals and all the gaskets....so whats the easiest way to do it..??? Thanks for your help.
Post A Followup
: Re: Stuck engine on an M
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
