Cub Repairs
Posted by Cubing in Tx. on October 22, 2002 at 20:45:50 from (64.132.17.113):
I would like a service manual for my Cub, I would appreciate your opinions as to who sells the
best one, my tractor is around a '56 model, I would like one that only covers the Cub.
A few more questions: 1: What type and wattage fuse is used in the light switch? 2: Why does the starter disengage as soon as the first stroke fires only to have engine die? If the engine is well tuned this is ok, but if it floods this is a pain. I believe the problem is with the drive, can you help to pin point the trouble? 3: How is crank pulley removed? 4: In S.Texas what weight of oils were factory recommended for use in the, Air filter, Crankcase, Trans/Dif., Steering box, and Final drives. Thanks in advance, you opinions are valued.
Post A Followup
: Re: Cub Repairs
