Re: Stuck engine on an M
Posted by Dave Wilcox on October 23, 2002 at 07:41:17 from (216.238.58.78):
In Reply to: Stuck engine on an M posted by Larry on October 22, 2002 at 17:26:57:
I have a Coop E3 that was found sitting in a
pasture for over 30 years. Hard to belive, but the
engine was set up. I did manage to get one piston
out. The rest would not move, so after several
days of thought, I came up with a sleeve pusher.
I took two pieces of 1 1/2" square tubing,drilled
a 3/4" hole in the end of both pieces for 3/4"
threaded rod, on one piece I welded a 1 1/2" by
3" piece of rectangular tube which would fit over
the connecting rod, and push directly on the
sleeve. length by TLAB {that looks about right}
Put one 1 1/2 square tube on top of the engine,
with 1/2" spacers so the sleeve could come up.
Put the other tube on the bottom with the rec.
tube over the connecting rod, and tightened the
nuts on the threaded rod. PRESTO, sleeves came
right out I SHOULD SAY , ON THE BUDA ENGINE,
the sleeves stuck down past the casting about
1/2". and the rectangular tube was just big enough
to push only the sleeve.
I wish I knew how to put a drawing on the tool
discussion board but I'm not that smart.
Post A Followup
: Re: Re: Stuck engine on an M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
