Re: Stuck engine on an M
Posted by Dale on October 24, 2002 at 11:37:06 from (134.84.43.16):
In Reply to: Stuck engine on an M posted by Larry on October 22, 2002 at 17:26:57:
I found this post facinating. What is a dead blow hammer? My experience: Had an O6 stuck motor. Soaked for 4 years and finally removed the head and pan and could remove the connecting rod caps on two pistons (other two were up in the motor). I put a piece of green treated lumber about 1 inch square (a piece of deck railing) up inside the piston and put a hydraulic jack under and jacked until the front wheels were partially up. Came back a few days later and found the sleeve up about 1/2 inch. Jacked more and the sleeve came out. Then removed the other one with the connecting rod loose, but the engine was still stuck. I put a jack under one side of the crankshaft and put pressure on, then released that and jacked the other side of the crankshaft. I could feel it move just a little, kept alternating pressure and it poppped loose. When those sleeves came out, the pistons was still stuck inside. Took both of them to the burning barrel, put diesel in and ligth the fire. After cooling, I could knock them out with a block of wood. I didn't use the old parts, put a new set of sleeves and pistons in. But that's where my progress ended for now. I may have been lucky not to damage the cs when I put pressure on it. I have a super A that had been redone. Didn't start it often enough and it is now stuck. Plan to use the same approach, but am concerned about damaging the crankshaft. Will appreciate any thoughts on this. Thanks. Dale
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
