Re: regulator smoking
Posted by pete 23 on March 28, 2009 at 09:07:44 from (173.87.1.12):
In Reply to: regulator smoking posted by Michigan A on March 28, 2009 at 08:26:36:
I am going to read your message as polarizing it for positive ground system. So, if you did this correctly by flashing the battery terminal at regulator(or from any hot terminal) to the armature terminal at regulator or generator you are correct there. If not, well. The resistors on the underside of a reglator get very warm and if during your process of working on this unit you maybe cleaned things with some solution it might be just cooking that off. Happens all the time when cleaning up a tractor. However, observe it carefully so as no wires are getting warm.
