Re: Re: farmall c leaking hydraulic fluid into engine oil
Posted by mark on October 24, 2002 at 18:25:46 from (152.163.189.203):
In Reply to: Re: farmall c leaking hydraulic fluid into engine oil posted by gene b on October 24, 2002 at 02:20:20:
so i guess ill go ahead and remove the pump and carry it to the dealer and get the parts. do i just unhook the lines from the pump and then unbolt the pump and take it off? what about where the lines hook up further back on the tractor, can i just leave them hooked up?
will it hurt to run the tractor any now?
thanks....
Post A Followup
: Re: Re: Re: farmall c leaking hydraulic fluid into engine oil
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
