Re: farmall c leaking hydraulic fluid into engine oil
Posted by gene b on October 24, 2002 at 02:20:20 from (67.251.189.65):
In Reply to: farmall c leaking hydraulic fluid into engine oil posted by mark on October 23, 2002 at 21:52:16:
the front seal on the pump is bad. There are two types used and you wont know until you remove the pump. If the journal is worn bad where the seal goes you will have to put on a speedy sleeve or the new one will leak after a little while. You can get the seals at the dealer.
Post A Followup
: Re: Re: farmall c leaking hydraulic fluid into engine oil
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
