Re: Stuck engine on an M
Posted by Dan on October 26, 2002 at 22:12:43 from (198.81.27.16):
In Reply to: Stuck engine on an M posted by Larry on October 22, 2002 at 17:26:57:
Well i think i have an easier way than some guys.I have a porta power and what i have done is made a plate that uses the head bolts on most engines to where i can put my ram upside down with either a plate against the piston or a piece of wood.What seems to be really tight using a dead blow usually comes out fairly easily with a porta power.You can rent them at most rental stores and i think i have a whopping 25 bucks in my grade eight all thread and any flat piece of steal can be drilled for the top plate.
Post A Followup
: Re: Re: Stuck engine on an M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
