Re: regulator smoking
Posted by Michigan A on March 28, 2009 at 09:22:18 from (66.19.17.59):
In Reply to: regulator smoking posted by Michigan A on March 28, 2009 at 08:26:36:
Sorry for misinformation. I go back and forth on Ford and Farmall boards and was thinking I was on the Ford board. I DID polarize to hot(negative) to the field connection NOT pos. On the Ford board one of the experts states to polarize from Field to Bat. Thanks for the idea about cleaning as I did some dirt and grease removal with the sheet metal off. I might not have noticed the small amount of smoke if the hood was on the tractor
