Re: Re: Re: Re: Farmall M Stuck in high gear
Posted by Rich on October 28, 2002 at 15:59:45 from (208.23.114.167):
In Reply to: Re: Re: Re: Farmall M Stuck in high gear posted by Farmer Bob on October 28, 2002 at 07:13:07:
I have same problem with Farmall 560 yesterday.
able to move in I beleive high gear but shift lever is in neutral. When move lever into 1 or reverse engine loads up like it will stall if I let clutch pedal all the way out. Am I probably having same problem ???
Post A Followup
: Re: Re: Re: Re: Re: Farmall M Stuck in high gear
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
