Re: Re: Re: Re: Re: Farmall M Stuck in high gear
Posted by Hugh MacKay on October 28, 2002 at 17:02:16 from (64.228.13.62):
In Reply to: Re: Re: Re: Re: Farmall M Stuck in high gear posted by Rich on October 28, 2002 at 15:59:45:
Do it soon shifting from 3rd to 4th as those Farmalls will do on the move and you happen to drop the clutch at full throttle, and tractor stays in 3rd and also goes into 4th, THEY WILL BREAK COGS. even a Farmall 300 will break cogs,I KNOW. Had Same happen with 560 luckily I didn't drop clutch out.
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall M Stuck in high gear
