Posted by JMOR on March 28, 2009 at 09:47:52 from (76.187.218.177):
In Reply to: regulator smoking posted by Bob 35 on March 28, 2009 at 08:26:36:
Jim, I'm not sure what gen type a 640 has, but if it is a type "A", where the regulator controls by grounding the field, then that is same as 8N Fords and if he applied battery power to field, then he probably did weld field points closed.
If he read on Ford board that you polarize by applying battery power to the Field, then he was likely reading about a NAA, Jubilee, or later tractor where the Gen is type "B" and control is by reg supplying power (not gnd) to the field.
OK, I just figured out that you apparently have a Ford 640, not a IH640, so you probably polarized correctly as it is type B.
This post was edited by JMOR at 09:54:31 03/28/09.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
