Re: Re: Re: Re: Re: FARMALL H WITH HEAVY METALIC NOCK
Posted by Harry on November 04, 2002 at 09:52:02 from (4.63.64.91):
In Reply to: Re: Re: Re: Re: FARMALL H WITH HEAVY METALIC NOCK posted by STEVEN H on November 02, 2002 at 22:32:38:
You may have a stuck or bent valve, given what you said earlier about the push rod falling out. If the valve stuck in the open position, there would be no tension on the rocker arm to keep the push rod in place. So the push rod fell out. The valve got hit by the piston comming up and bent the valve, and may have damaged the piston too. So every time the piston comes up, it makes contact with the valve and makes the loud metallic sound you are talking about. My suggestion is that you remove the head and inspect the valves and tops of the pistons for damage. The last thing you want to do is put bearings back in the beast and then have a piston crack and take out the crankshaft or rods. Don't put used bearings from one engine into another. The wear patterns will not match up and you will be tearing the engine back down and re-grinding the crankshaft. If your crankshaft looks good, just clean up the journals and put new mains & rod bearings in it. You never said how much oil pressure the engine was running before this happened. Do you have a working oil pressure guage on the engine?? If not, spend the money and get one so you can see what is happening. Good luck ,and keep us posted on what you find.
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
