Re: Farmall M Fuel sediment bowl
Posted by Puller504 on November 07, 2002 at 14:02:28 from (65.238.81.188):
In Reply to: Farmall M Fuel sediment bowl posted by David on November 06, 2002 at 20:47:11:
Remove sediment bowl assembly. Label and shelve it. Pipe dope, close nipple, 3/8" shutoff valve, Street ell, 3/8" fuel hose fitting. Assemble and install. Use 3/8" paper fuel filter cartridge, hose to fitting at carb. Tighten clamps on fittings. Problem solved, permanently. Sure, it's not "factory", but neither is the electronic ignition!.
Post A Followup
: Re: Re: Farmall M Fuel sediment bowl
