Re: Farmall M water pump grease?
Posted by Charlie G on November 07, 2002 at 18:19:55 from (66.43.210.205):
In Reply to: Farmall M water pump grease? posted by Roger Seargent on November 07, 2002 at 17:36:26:
My manual says to use chassis lube grease, just two strokes per fitting each 10 hrs of operation. The lower fitting is the shaft bearing and upper is the packing. Must work OK 'cause I'm on the second pump since new in '53.
Post A Followup
: Re: Re: Farmall M water pump grease?
