Re: Re: Farmall M water pump grease?
Posted by SBM on November 10, 2002 at 09:42:59 from (195.241.64.67):
In Reply to: Re: Farmall M water pump grease? posted by Charlie G on November 07, 2002 at 18:19:55:
I have a SBM, don't know if it is different, but:
the upper fitting is for the bearings of the pulley,
the lower fitting is for the waterpump axle.
In my case I have replaced the pulley bearings with closed bearings (cannot be greased). If I should use the upper fitting, I'd damage the bearings very bad!
Wonder why your fitting wears a cap...
Post A Followup
: Re: Re: Re: Farmall M water pump grease?
