Farmall Tractors Discussion Board
Re: W-30 torque specifications
Posted by David Saville on August 25, 1999 at 21:44:48 from (142.165.111.91):
In Reply to: W-30 torque specifications posted by Philip Reitcheck on August 25, 1999 at 10:42:17:
I have a reprint of the shop service manual and I remember distinctly what it says for the cylender head torque, and I quote "tight". In fact a couple of those bolts can only be tightened with an open end wrench. Similar info is given for other engine parts. It also says to "remove shims in the connecting rods untill they are not too tight".
Post a Followup
: Re: Re: W-30 torque specifications
