Re: Re: BOLT head on the loose
Posted by STEVEN H on November 09, 2002 at 13:53:46 from (209.103.199.94):
In Reply to: Re: BOLT head on the loose posted by Roger on November 09, 2002 at 10:45:39:
Thank you roger that was the ticket dont use the choke much in september so dont know why it would have came of. also does the brass not brake as ez or why do they recomend that?
Post A Followup
: Re: Re: Re: BOLT head on the loose
