Re: Changing SM cam gear
Posted by Dan on November 09, 2002 at 19:54:03 from (12.144.247.66):
In Reply to: Changing SM cam gear posted by Bart on November 09, 2002 at 11:51:44:
Do you have any books on it, ie IT of Blue ribbon? Bob M has good pictures. I Had to chage the camshaft on my SMTA. Blocked the rear end under the front of the transmission case. The front pedestal has to come off so take the steering shaft loose at the u joint and the bolts on the sides of the frame. You also have to loosten the bolts on the rear of the frame by the back of the engine and the engine bolts to frame slightly. You have to have some way to handle heavy objects a front end loader works well. Oh you also have to drain radiator and loosten top and bottom hoses. Don't forget to remove brace from mid section to top of radiator(can tell you from experience) With a tricycle front end they want to turn over so if you can somehow prevent that it helps. ONce the front pedestal is out of the way you have to take off belts and crankshaft pulley. That takes a 2 1/2 inch socket. After that is just front cover. Change gear and check timing marks on gear and mating gear. When you put it back together don't forget the oil flinger on the crankshaft(again from experience). Not a bad job if you have some posts of something to securely block the back and a loader or overhead hoist to handle the front pedestal.
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
