Posted by JMOR on March 28, 2009 at 12:03:43 from (76.187.218.177):
In Reply to: regulator smoking posted by 63 830 on March 28, 2009 at 08:26:36:
garytomaszewski said: (quoted from post at 13:34:33 03/28/09) I'll try this once more, on a Delco generator/regulator to polarize you momentarily touch the BATTERY terminal of the regulator to the ARMATURE terminal NO MATTER WHAT THE POLARITY OF THE GROUND. Grounding the Field terminal bypasses the regulator and gives full generator output to the battery. I will guess that you probably welded the FIELD circuit and are indeed charging 8-10 amps.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
