Re: Question for Bob M
Posted by Bob M on November 11, 2002 at 07:35:53 from (165.170.128.68):
In Reply to: Question for Bob M posted by Krey in Indiana on November 11, 2002 at 05:21:29:
Krey - Sounds like you have a "one wire" 10SI alternator. This requires no external wiring to start/control alternator operation. A standard 3-wire 10SI on the other hand requires switched 12 volts at the #1 terminal (to turn on/shutdown regulator), and unswitched 12 volts at the #2 aux terminal (for the internal regulator to sense system voltage). If a lamp is inserted in the line between the ign switch and the #1 terminal, it will serve as a charging system warning lamp, same as in the dash in your car. The lamp will light if the system stops charging (broken drive belt, alternator failure, etc) On a 3-wire setup, if you don't want a warning light you must substitute either a resistor or a diode in place of the light. If you DON'T have one of the above, the #1 terminal will backfeed 12 volts to the coil side of the ignition switch when you try to shut the engine down. This will make the motor to continue to run after the ign is switched "off".
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
