Farmall Tractors Discussion Board
Re: Farmall A runs and then sputters to death in 20 minutes
Posted by Pat H. on August 26, 1999 at 07:51:04 from (216.145.144.108):
In Reply to: Farmall A runs and then sputters to death in 20 minutes posted by Marty on August 26, 1999 at 06:44:29:
I had a super H do the same thing. Thought it was fuel related but turned out to be the ignition coil.When coil warmed up it had much weaker spark,used to take about15 minutes.Tractor then wouldn't start until it cooled down.Hope this helps.
Post a Followup
: Re: Re: Farmall A runs and then sputters to death in 20 minutes
