Re: F-14 questions
Posted by F14 on November 12, 2002 at 09:05:16 from (216.204.137.219):
In Reply to: F-14 questions posted by LP on November 12, 2002 at 07:48:09:
The F12/F14 is a very common tractor. The tractor you describe would go for more like $750 ***RUNNING*** and driveable around here. In the condition you describe, I wouldn't give more than $500 for it, including the plow, and IF he threw in a working magneto.
If he's starting at $1000, I doubt you'll be able to talk him down to a reasonable range, I'd keep looking.
And, Yes, a fully mounted plow was available.
Post A Followup
: Re: Re: F-14 questions
