Re: Steering problems
Posted by Bill L Md. on November 12, 2002 at 10:34:32 from (205.188.209.78):
In Reply to: Steering problems posted by Brcye Andreasen on November 12, 2002 at 08:44:17:
Brcye, quick fix ,take the sheet metal off ,take the cover off the upper bolster (6- 9/16 inch bolts I believe)take cotter key out castle nut off,find a big enough washer to go over shaft (change oil or grease while their)re assemble .don't over snug castle nut but get it fairly tight.Check the castle nut first see if their is any adjustment left,if their is snug nut down,see how it works.
Post A Followup
: Re: Re: Steering problems
