Farmall Tractors Discussion Board
Re: Farmall A runs and then sputters to death in 20 minutes
Posted by paul on August 26, 1999 at 09:09:25 from (128.8.186.117):
In Reply to: Farmall A runs and then sputters to death in 20 minutes posted by Marty on August 26, 1999 at 06:44:29:
Our H acted similiarly and found that there was a fuel restriction in the tank. A piece of leaf was floating around and would periodically become lodged on the tank outlet. After sitting for a while the trash would float off and the tractor would start and run fine until the next occurance. Took awhile to realize what was happening but draing the tank completely was the fix.
Post a Followup
: Re: Re: Farmall A runs and then sputters to death in 20 minutes
