Farmall Tractors Discussion Board
Re: Farmall A runs and then sputters to death in 20 minutes
Posted by Jon H on August 26, 1999 at 12:25:01 from (207.239.152.110):
In Reply to: Farmall A runs and then sputters to death in 20 minutes posted by Marty on August 26, 1999 at 06:44:29:
If you don't find a fuel problem replace the points and condenser. Problem condensers fail more as they warm up and begin to work after they cool down.
Post a Followup
: Re: Re: Farmall A runs and then sputters to death in 20 minutes
