Int 1486..... NO hyd output -- only fwd and rev gears
Posted by Ron B on November 16, 2002 at 14:52:52 from (216.220.131.229):
Hello,
I have a INT 1486. Something happened to the hydralics.. It has no pressure and the pump is not pumping, nothing works but the fwd and revers gearing.... I pulled the hyd. pump off and inspected it, it looked fine.... I reached my hand inside the trans (while I had the pump off) and I could turn the gear that turns the hyd pump. I was told this gear should not move with my hand, well it does! Has any one had this problem? What am I going to have to do to fix it?? I was told I will have to split the tractor to fix it.... Do you have any suggestions or ideas?? What exactly will I be looking at to fix this monster??
Is this a job I should attempt??
I am new to tractors and don't know to much about them but can learn fast and plan to fix it myself with your help!
Thanks Ron B
Post A Followup
: Re: Int 1486..... NO hyd output -- only fwd and rev gears
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
