Re: Int 1486..... NO hyd output -- only fwd and rev gears
Posted by Rich on November 16, 2002 at 15:04:22 from (216.248.123.249):
In Reply to: Int 1486..... NO hyd output -- only fwd and rev gears posted by Ron B on November 16, 2002 at 14:52:52:
Sounds as if you have stripped the splines on the stub pto drive shaft which drives your hyd.pumps. This means that you have to split the tractor at the clutch houseing. It will be obvious what you have to do after you get that done.
Post A Followup
: Re: Re: Int 1486..... NO hyd output -- only fwd and rev gears
