Farmall Tractors Discussion Board
Re: Re: M Farmall rear grease seal
Posted by BDM on August 26, 1999 at 20:23:04 from (24.2.72.179):
In Reply to: Re: M Farmall rear grease seal posted by RED Blooded on August 26, 1999 at 18:26:28:
Yup, thats the way, I would also wire brush and clean the axle before sliding the new one on. I did mine before removing the old one, as there was rust, dirt and scale. They used to use a real thin tube that would slide over the axle so the seal could slide on without tearing on the axle key way. Just grease it and very carefully slide it over slowly until its home.
Brian
P.S. you can also mail order the parts if need be.
Post a Followup
: Re: Re: Re: M Farmall rear grease seal
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
