Farmall Tractors Discussion Board
Re: Re: Use of unleaded Gas
Posted by The Red on August 27, 1999 at 12:28:04 from (206.246.187.2):
In Reply to: Re: Use of unleaded Gas posted by steve on August 27, 1999 at 11:49:41:
About the only strenous activity my Hs get is pulling a loaded 250 bushel hopper in the fall. It is pretty much running flat out when you do that. About the only other thing that would push an H hard is if you are actually still plowing with a 2 bottom. You don't see much plowing in Indiana anymore.
Post a Followup
: Re: Re: Re: Use of unleaded Gas
