Re: Re: SuperM cam gear and shaft
Posted by Bart on November 24, 2002 at 11:56:39 from (64.30.54.124):
In Reply to: Re: SuperM cam gear and shaft posted by Bob M on November 24, 2002 at 05:07:01:
Bob M. You're absolutely right. I hadn't thought of welding the woofruff key back in it's slot. My tractor probably won't get a lot of use anyway. The way it got broken is someone installed a closed center hyd. valve. Cracked the pump and everything else it seems. Many thanks to you for taking the time to respond. Any snow over in New York? Almost time to hibernate here in Vermont. Thanks again.
Post A Followup
: Re: Re: Re: SuperM cam gear and shaft
