Re: SuperM cam gear and shaft
Posted by Bob M on November 24, 2002 at 05:07:01 from (24.169.120.229):
In Reply to: SuperM cam gear and shaft posted by Bart on November 24, 2002 at 03:08:37:
Hey Bart - We encountered the same thing (badly worn camshaft keyway) on a buddy's 400 a few weeks ago. Solution was to tack weld the new key into the damaged keyway, then install the new gear on this "repaired" camshaft. On my Super M (which I had to relace the cam gear several years ago) I found one side of the camshaft keyway missing entirely - apparently it had chipped out when the gear came loose. Not wanting (or being able to afford...) to replace the camshaft, I installed the new gear and key so one side of the key was against the remaining good side of the keyway. Figured the key only keeps the cam gear located until the cam nut is tightened. Once that nut is tight, the camshaft torque load is taken by friction between the back of the cam hub and the gear's rear hub face - the key is just along for the ride. So the damaged keyway would not be a problem. I must have been right because the SM has since accumulated a couple hundred hours of operation and is still running great. Some of those hours were with heavy hydraulic operation - operation that causes the most stress on the cam gear and hub. Good luck with yours!!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
