Re: Re: SuperM cam gear and shaft
Posted by Heath on November 24, 2002 at 18:00:00 from (208.29.50.254):
In Reply to: Re: SuperM cam gear and shaft posted by Bob M on November 24, 2002 at 05:07:01:
I don't know how hard the gear hub and cam are but if you can, drill one or more 1/4" holes endwise in between the hub and the shaft parrallel to the old key about 1" deep. Tap them out 5/16" and install a bolt or set screw which will lock it up better than a key. I have used this on stripped splines and it handled over 150hp and also in the stripped thread on gears in an M belly pump as well as many other pulleys etc. It is better that a key.
Post A Followup
: Re: Re: Re: SuperM cam gear and shaft
