Re: not tractor but need help with engine
Posted by rhouston on November 25, 2002 at 06:43:36 from (24.48.66.19):
In Reply to: not tractor but need help with engine posted by Chad Penny on November 25, 2002 at 05:54:39:
I would pull the pan after engine flush. just lost an engine in RAM to a clogged sump screen. chunks pack inside pickup tube and cause low oil pressure/volume seized the engine. that's also the reason I won't install a used engine. years ago a friend flushed an engine then ended up with low oil pressure I beleive that is what happened there also.
Post A Followup
: Re: Re: not tractor but need help with engine
