Re: M farmall pto seal, how to knock out old shaft seal?
Posted by Mike ISW on November 30, 2002 at 20:51:33 from (152.163.189.203):
In Reply to: M farmall pto seal, how to knock out old shaft seal? posted by aaron on November 30, 2002 at 15:05:38:
A little trick I did with that seal was I wrapped the splines with electrical tape and then greased liberally. Seal slide down shaft nicely and didn't have to worry about nicks. Putting that pto shaft back in place will be tricky but can be done. I put mine back in with top cover off so I don't know the trick to it. may take a second person to hold a light up in there to see where you're at. Good Luck, Mike
Post A Followup
: Re: Re: M farmall pto seal, how to knock out old shaft seal?
