M farmall pto seal, how to knock out old shaft seal?
Posted by aaron on November 30, 2002 at 15:05:38 from (198.81.27.16):
How does a fella knock out the shaft seal and insert the new rubber o ring seal? Also, I accidently pulled on the shaft after I took the housing off and the fool thing came unjoined in the transmission. How do I reinsert the shaft?
thanks
Post A Followup
: Re: M farmall pto seal, how to knock out old shaft seal?
