Re: M farmall pto seal, how to knock out old shaft seal?
Posted by Harold Hubbard on December 01, 2002 at 04:27:38 from (216.114.175.234):
In Reply to: M farmall pto seal, how to knock out old shaft seal? posted by aaron on November 30, 2002 at 15:05:38:
To put the shaft back in: find a piece of pipe that will just fit over the outer end of the shaft, and about the same length. Use the pipe to hold the shaft level as you put it into the case. the extra length gives you leverage to balance the assembly.
Post A Followup
: Re: Re: M farmall pto seal, how to knock out old shaft seal?
