Re: Piston Sleeve Removal
Posted by Tom on December 01, 2002 at 15:40:02 from (198.108.134.176):
In Reply to: Piston Sleeve Removal posted by Shawn on December 01, 2002 at 15:13:02:
Shawn, On those occasions where I do not remove the engine from the frame or crank from the engine, I cut a piece of metal and place it across the bottom of the sleeve. Then I position a hydraulic jack under it and press it out. If it is still stuck, place a piece of wood (4x4) on the top off the block (not over the sleeve being removed) and wrap it with a sledge hammer. Usually with the pressure of the jack and a sharp blow the sleeve will pop loose. Keep us posted. Tom
Post A Followup
: Re: Re: Piston Sleeve Removal
