Re: generator voltage adjustment info..
Posted by Bob M on December 02, 2002 at 17:50:04 from (24.169.120.229):
In Reply to: generator voltage adjustment info.. posted by IHMan on December 02, 2002 at 16:03:50:
There's 2 relays inside the regulator. Find the relay that has it's contacts held SHUT by spring pressure - this will be the voltage relay. (The other relay has it's contacts held OPEN by spring pressure - it's the cutout - not the one you want). The spring tension in the voltage relay determines it's output voltage - the higher the spring tension the higher the voltage. Depending on the relay design, spring tension may be adjusted by turning a screw or by bending the relay spring hanger. To adjust the voltage, connect your DVM to read battery voltage directly off the battery posts. Now start the motor and run it near full RPM. While watching the reading on the DVM, very carefully increase the voltage relay spring tension. Do this slow and easy - a small change in spring tension will cause a larger change in voltage. When you get a DVM reading of 9.0 to 9.1 volts, you've got it. Good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
